1 - 18 of 18 Posts
I took delivery of my GT TDI on Thursday and am not sure if the variable service interval is enabled. Is there anyway of checking this without going back to the dealer? If so, is there also a way of checking to see how long before it will need servicing?
Yes.
Turn on the ignition till the lights come on. Press and hold the trip reset button for a few seconds. It will come up with "service in X miles" and then after a few seconds change to "or Y days"
X should be about 18k miles.
Y should be about 2 years.
If it comes up in 365 days you are on fixed.
Does this work on mkIV's too?
My mates is telling him he needs a service about 10k after his last variable one which sounds suspiciously like he's been put onto fixed by mistake.
Only way to do it is with VAG-COM on a mk4. If the service comes on at 9300 ish then most likely its on the 10K service intervals (15000 km conversion figure)
HTH
I am starting to ponder if it matters about variable or fixed, if the car has don't 10000k or 18000k miles it need a service no matter what "mode" its on. The oil, engine etc etc as done that same amount of work.
Is this me being stupid or do I have a point?
My car was reg in April 04 and I bought it in Feb @ 10200 on the clock, I checked it at 12000 and its saying I should service it now, I asked VW and they said all 04 plate cars are on variable (lazy bams). I am not going to service it till it its 18000.
Yes.
This does not work for me, so either I am stupid or something is wrong. Do you need to have done a minimum number of miles before this displays? I have done 491
How often your car needs an oil change is dependent upon useage. If you do lots of long motorway cruises, a new car's oil after 18,000 miles might be in the same state as a car with only 5,000 miles on the clock if its only been used for short trips around town.
Fixed service intervals are always an estimate interval based on average use. VW's variable service intervals is an attempt to be more accurate by detecting the quality of your car's oil and indicating when a service is required based upon that.
In your case, it is possible that the previous owner did do a lot of motorway miles and so the car got to 10,000 miles without needing a service. Your car might or might not have been saying it needed a service when you bought it but the fact that it says so now suggests it thinks the oil needs changing now. I'd recommend you get it serviced .
Stuart
http://www.stuartdalby.co.uk/vwgolfmk5
I Have just over 5000 miles on my GT TDI, and since I found out how to check when the service was due, aproxx 2000 miles, it tells me to SERVICE NOW
what is the problem?
My Car has a service sticker on the side of the daskboard, visable when you open the drivers door tell me that I am on the long life service.
Can I just check?
You turn on the ignition but not the engine, then hold down the trip reset (not the reset on the stalk but the one on the instrument cluster) for a couple of seconds?
The bloody thing does not work for me.
1 - 18 of 18 Posts
