Bill
I couldnt use the N75, as it was overboosting all the time !! jabba sent me more chips and boost problems wasent solved, so had to remove N75. Car runs very smooth, i got my valve from boostvalve.com , the problems I have is that jabba needs to adjust the timing a bit lower and also lean it a bit, but all will be set when I install my FMIC
Remeber mine is an AGU engine, no map sensor, or it doesnt make any difference ???
