Anti roll bar options.
1034 Views 11 Replies 6 Participants Last post by  cobby
Right looking for some uprated anti roll bars.
What have other people got?
Currently looking at kw or H&R anybody had experience with either?
1 - 12 of 12 Posts
i have whiteline rear and front. How low are you planning to go?
What feel are you wanting from the setup as the H&R and KW offer quite different characteristics.
[email protected] DPM Performance
Looking for the best performance to be honest,
Do they both stop rubbing on the drive shafts?
Whats the differance in them Damian?
The H&R will give you more of an improved factory balanced feel where as the KW will give more oversteer with the rear bar being the same size as the front.
Damian @ DPM Performance
Would you recommand damian?
I presume there both better than whitline?
Depends how low you want to go as well as the Whiteline front bar will give you the most clearance.
A lot is down to personal preference so if you want more of a balanced feel then I'd say H&R and if you want more overtseer then I'd say either KW or Whiteline.
What are you eibach 25mm ones on your site like Damian? Always wanted a Rear ARB to keep the car more controlled on the corners.
Good kit and reduces a lot of the understeer.
If your just fitting a rear and keeping the front standard then I'd say go for the Whiteline rear bar.
I have eibach front and rear ARB with coilivers all round. Handles like a dream. Even when the car was -90mm (For a day due to poor roads) the ARB didnt rub at all.
1 - 12 of 12 Posts
