1 - 7 of 7 Posts
For the last 3 months i have this annoying thud noise coming from the right side of the engine area, it usually most audible when i turn left or rever back and turn off to the left.
Today i have changed both anti roll bar bushes and Droplinks and both topmounts, however the noise is still there, i was hoping it woudl of been the top mount but as soon as the other one was out i could tell that this wouldnt of solved the problem.
So am still where i began is there anyone has any experience with this sort of clonk/thud noise. I have changed the dogmount recently.
cheers
i had similiar a year ago
turned out the control arms were loose(slightly)
vw lifted the engine and then re-torqued them up...and no more noise
Right to date, i have changed
Both Strut Top Mounts
Both ARB Bushes
Both Droplinks
Am thinkign it might be in need of a drivers side wishbone and possibly balljoint, as these are the cheapest to replace.
Done a quick search on here but theres nothign conclusive as to what it may be.
Again the symtoms are when i turn and it definelty comes from the front drivers side area, sometimes you can feel the thud/twang noise in the pedals.
Any help much appreciated.
i did all that as well...and then found out the bolt holding the wishbones together was slightly loose
i replaced exactly all that
Storm: if your bolts to the wishbone were loose then why did vw have to lift the engine lol. I am gonna go get the subframe bolts tightened up check all bolts etc tomorrow
1 - 7 of 7 Posts
