Bit of an intermittent problem that I've got with the VR.
When I'm at high revs, I sometimes get alternator workshop appear with the battery light flashing - is this likely to be the voltage regulator? Or am I looking at a complete alternator? Any chance it's just a slipping belt?
There's also a slight whine when getting through the revs, which I have a feeling is linked and is the alternator. Like on the TDIs, is the alternator pulley a clutched pulley?
Unsure if related (probably is), but when cold, there's a small squeak from the accessories, haven't yet looked into whether it's belt, tensioner or an accessory pulley.
And lastly, doesn't look like there's much room around it, so is pulling the front end off the easiest way to get to the alternator, or is there another way to fish it out?
Voltage at idle seems normal, around 13.7V.
TIA, as always.
TIA, as always.
