1 - 9 of 9 Posts
After a long trip yesterday, after filling up the 'Air Bag' fault was displayed on the MDF along with a yellow warning on the Dash.
Getting a tad fed up of this car at the moment.
I've tried to clear the fault code but it keeps coming back.
Before I take it to the dealers anyone know what to look for?
cheers.
I have an air bag fault recently , this was after changing my head unit. and the airbag on/off switch cable had worked it was loose. have you changed anything recently??
have you scanned your car with VCDS to see which bag is playing up. bet it is one of the seats
Ive scanned with my ST3 and no error codes came up. I will check with VCDS later today.
Nothing has changed in the car, ive also checked all the cables underneath the seats.
well the car went in for a service today, and the techs said it requires a new connector under the seat.
Now, they say this is not covered by VW extended warranty as it is an electrical component. I was mighty peeved at this considering the car is only 2.5 years old!
Chief Troll
95% of airbag faults on the mk5s are cause dues to a fault in the underseat wiring.
Sounds like BS about the warranty though, push them for it to be replaced.
They are getting around it by saying;
"Electrical wiring connection blocks, terminals and fuses" is not covered and this is from VW UK.
Any idea what I can look for?
Shafted again by VW.
Even suggest that the DPF is looked at in the next 10K - excuse me, DPF cough, cough whats that.....
Hi
if your good with a soldering iron, it is easy to cut the plugs off and solder the wires together. I did this to a friends GTi, VW wanted over £80 to fix it. I did it in 30mins.
1 - 9 of 9 Posts
