My old 1.4 still uses a lot of oil, I used to start a 185 mile journey with a full dipstick and by the end it would be touching the minimum mark. I had it compression tested and it all checked out fine, mechanic reckoned oil rings could be gone but compression rings still holding hence the compression test checking out. This one also has shit loads of mayo in the breather and oil all over the air filter, a friend of mine bought it off me cheap, and I'm planning to go up and give the breather assembly a proper clean out when I get the chance. I've also heard the EGR valve can clog up on these engines, is this true?
