Hi , very happy as ive just added the two new bora keyfobs to my golf, and the boot release works!!!, well it unlocks the boot lock, all i need now is the mechanism from a bora to pop it open as well and hey presto!!!, the way i coded the alarm fobs in was this way:
open the car
put one key in the ignition and turn it on so that the dash lighs come on, dont turn the car over!
then open the drivers side window
close the door
put the other key in the drivers door and lock the car
then press the unlock button on the new fob twice, but give it a 1 second gap before pressing it a second time
on the second press the alarm siren will chirp once .
thats it !, open the drivers side door with the key , then remove the ignition key and its coded!
the bora fob is great as when the cars locked you can open the boot seperately from the fob, which deactivates the alarm allowing you to open the boot, then when you close the boot it arms itself by itself after 30 seconds, neat hey?, and you dont need to change any convienence module or anything else, ive got the wiring diagram for the boot release module fitted to a bora , and as far as i can see it only needs the bora boot release module, after a bit of fiddling, i,ll have this fitted and hey presto , a boot which pops open !!
