1 - 7 of 7 Posts
ABS only kicks in when one of the wheels lockup.. it'll release a bit of the pressure on the caliper of said wheel than as long as your foot is on the brake pedal it'll keep doing that until the car has come to a stop or you've removed your foot from the brake pedal ( it does this on all four calipers if needs be by the way)... whatever comes first.
that said, it makes a big difference in stopping distance so i would try and sort it out asap, because it is there for emergency braking and that is when it helps shorten the brake distance.
so i did a visual check of the fuses that are maked on the diagrams as anything to do with the ABS. checked under the bonnet and the drivers side panel fuses. all look fine none are gone?
Gas Electrical wiring Machine Audio equipment Font
Motor vehicle Automotive tire Fluid Automotive wheel system Gas
any advise on how i check the earth and leads to the actual ABS module
right so bite the bullet and get it replaced.
what is the correct code? SW or HW?
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
1 - 7 of 7 Posts
