Hi I noticed that a lot of people who have santa's always get some type
of laquer corrosion on their alloys like I had on mine when i baught
them they were like this
So instead of paying a refurber X amount of money I refurbed them myself all for ?25, Heres what you need.
2x Project packs of Wet n Dry from Halfords ?5 each
1x Peek polish liquid form. ?10
24x Sanding Blocks ?5 from local DIY shop.
So Firstly I sanded down the remaining laquer that was on the alloys by
hand, So I firstly used 120 Grit Wet n Dry on the alloy to take off the
mejority of the laquer, then I used a 400 grit Wet n Dry sandpaper on
the alloys to take the roughness out of the alloys and smooth it down a
lot. Then I used a Sanding Block to create the same pattern in the
alloys so i went up and down each spoke so they all looked the same.
Then I used a 800 grit Wet n Dry paper and again sanding in the same
direction. Finally I used a 1200 grit paper again sanding it down in
the same direction leaving a super smooth finish on the alloy. Then I
gave the alloys a wash down with some water, and let them dry off.
Heres a pic after what I done.
Now for the polishing I used a buffing machiene with an abrasive sponge
on it. I poured the Peek polish directly on to each spoke and spread it
all over the spokes via a cloth so all the metal has polish on it. Then
I used the buffer on the alloy the first time I polished the alloy I
used speed 2 so the polish would buff it quickly, once I polished the
whole face of the alloy I wiped down the residue of the polish so i had
a smooth and shiny surface, then again without applying any more polish
I used the buffer again but at a lower speed (speed 1) but this time I
concentrated and pushed down hard on each spoke so I got the maximum
shine out of the metal. Heres a pic of the final product.
But after all this DO NOT apply laquer to the alloys because it will
leave a dull appearance on the alloy and then you will have to do this
procedure all over again, just apply 4-5 coats of wax. Hope this little
'how to' helps all the Santa Monica owners. [y][y]
Sonny
Sonny
