Thought I would just post some pics of the 42 Draft Design Pod install.
This just focuses on the route of the boost tube from engine bay to interior and actually attaching the pod on to the A pillar. (This is for AGU engine). The boost tube route through the bulkhead will obviously depend on the position of the grommet you choose.
I chose to run the tube into the cable box (this has a spare grommet) which is under the windscreen cowling. This leads straight into the interior cavity behind the fuse box cover. I used some convoluted sleeve loom to encase the boost tubing and installed a grommet leading from the engine bay (used a hole punch for this). Although this involves a little work, the result looks very OM.
A member on here used the same route (I think it was Pope) and I also found a guide on the Vortex forum, although in that case in was for a ICE cable run. The link to this is http://forums.vwvortex.com/zerothread?id=1835153
The pictures at the end are just of the Pod attached to the A pillar. I included these because I used heavy duty Velcro (B & Q store) and this works very well and creates a tight fit. The bonus being that you can easily remove the pod if you have to.
(nb. The 1/4 inch convoluted sleeve can be obtained from this link to Europa Specialist Spares -- useful stuff if anyones interested https://secure.visav.co.uk/avshop/products.asp?getcats=true&cat=24&scat=56&sscat=26 )
Anyways : [
http://pic3.picturetrail.com/VOL17/1625480/3141791/95878263.jpg
http://pic3.picturetrail.com/VOL17/1625480/3141791/95878258.jpghttp://pic3.picturetrail.com/VOL17/1625480/3141791/95426645.jpg
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o
></o
Anyways : [
