1 - 7 of 7 Posts
Theres 5 sensors in the exhaust I have for my conversion.
All have come to me cut!
So I'll try and rejoin the wires, with sum stainless solder.
Tberes a sensor on the down pipe, the 5th sensor, wots this for?
Do you know if all the sensors actually work? Also, depending on the mileage of the car it came off - you may want to ditch the catalyst before fitting back on. It looks half baked tbh and these don't always rattle when gone.
Not sure what the 5th sensor is as there are only 2 lambda sensor pre-cat ports on mine...
Wood Tool Metal Pipe Composite material
As for them working?
I have no idea.
Theres 2 b4 and 2 after cat . Both cut.
The 5th mayb a temp?
Which sensors can I have mapped out.
I believe you can map 2 of the sensors out?
Pre cat?
1 - 7 of 7 Posts
