Well, that escalated quickly! lol I set out to look into our no AC issue and also some "woolly" throttle response on our latest toy (abused and thrashed VR6 6-speed highline 4Motion) and also to trace out some sketchy DIY wiring work behind the battery tray (see below for the 10A fused wire direct from batt + to a sensor at the back of the engine/box)
However, on closer inspection there was a lot more than initially met the eye...
That's the melted/hacked/spliced remains of the reverse lamp switch and starter trigger wires. And this...
Is what greeted me inside the loom trunking. There's obviously been a small electrical fire in this area under the battery at some point, although not into the loom above & not sure what the splices there are about yet...
Following my nose (or more accurately, the gooey mess of insulating tape) led me to the larger ECU plug & this...
There was a bit of insulation damage to the green & black twisted pair from the MAF plug so I'm hopeful that was at least part of the running issue. More worried about the "repairs" from this plug going towards the interior though, not sure why the orange twisted pair has been spliced/taped & then there's the grey/white wire that originally went to the orange plug on the bulkhead connectors...
As can be seen, this has some evidence of overheating although NOT on the grey/white wire (which had been overlaid and run direct to a bundle under the dash, more on that later though.) but on the red.green wire that runs to the ECU plug
That's not good! Looks like it might have been a bad connection although the heat has travelled a fair way up the wire, it hasn't got crispy all the way along... The red/green and grey/white go to these pins on the large ECU plug...
And no sign of distress at that end of the run. So, that's all so far on the engine bay side of things. Not nice, but not horrific either and certainly can be fixed without too much faff. However...
There's the small matter of this little grey/white wire that was cut and overlaid (admirably in the correct colour and gauge of wire, although that's where the good-ness ends!). It was twisted and taped onto the corresponding tail left on the ECU plug & run through the bulkhead connector block...
Coming out behind the dash & running NOT to the other side of the orange connector block as common sense would seem to dictate, but to this...
(see next post)
Sensitive content, not recommended for those under 18
Show Content
(see next post)
