EDIT: and yes I have searched the forum but everybody else's problems seems to be worse and have more codes.
To start off, I bought the car Saturday off a forum member here.
2001 (X) 1.8T AUM
Car starts fine when cold and idles at 1100ish for about 1 minute then drops.
Then when warm and slowing to lights the revs drop to about 700 and then bounces as if to stall but it doesn't, it does this a few times when sat at the lights but mainly only bounces about 50rpm but you cant hear it fluctuating.
And then sometimes when pulling away it feels hesitant.
I scanned with vag com and got the code 17705, and another because I had disconnected the battery.
I have checked the throttle body and it is slightly oily but not very bad, I will get some TB cleaner after work tomorrow but wondered what your opinions might be.
The engine is completely stock apart from a pipercross panel filter.
It has recently had the temp sensor replaced because of the idle issues but obviously it didn't fix it.
2001 (X) 1.8T AUM
