how do brainy peeps just a quick question i'm in need of a 12v ignition switched feed some where near front bumper area of the car had a bit of a poke around with multimeter but not found anything only going to be running some led DLR lights from it so not a big feed needed
The reversing light switch on top of the gearbox has an ignition switched input and should be a bleck/green wire.It's not very thick though so it would be a VERY good idea to relay it if you want to power anything else from it.
As in come Bring a spur off it to one side of the coil of a relay, then the other side of the coil to earth.
Then feed the common side of the relay with a suitable permanent live. Straight from the battery positive terminal, and use the Normally open (other side) of the relay to run your DRL's
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Volkswagen Mark IV Forum
