1 - 8 of 8 Posts
hi guys im new to the forum, please be nice haha :) got a problem that VERY annoying help would be much appreciated, here goes...
got a golf gt tdi 115 2001 y reg and the remote Central locking does not function, The car can be
unlocked manually but the drivers door pin stays flashing once unlocked,
the alarm siren will go off if any door is opened before the ignition
is activated.. tried
to reprogramme the key by turning the ignition on and unlocking the dor and blah blah blah to no sucess.... also the back windscreen washer jet dosen't work haha
Does anyone have any ideas on how to solve this problem please!! :)
Where do you live?
There are loads and loads of people who can scan your car and try and reprogram your remote for you using VCDS (also sometimes called vag com).
The most likely cause is a faulty door lock or CCM unit. Either part could cost upto £50 to replace diy style.
Don't be fooled by thinking it's only VW who can help
cheers aham, got a mate with vag com just scanned it now, got 3 codes back
16955
17978
17664
but non of these are in the manual will do a bit of reasearch, thanks for all the replys guys
From Rosstech's wiki site
http://wiki.ross-tech.com/wiki/index.php/16955/P0571/001393
http://wiki.ross-tech.com/wiki/index.php/17978/P1570/005488
http://wiki.ross-tech.com/wiki/index.php/17664/P1256
You can do with a replacement coolant sensor and check your brake lights work, other than that nothing serious.
If you have access to VCDS, turn on the alarm beep for locking and unlock. Locking with the key, if it beeps then its locking properly.
unlocking with the key, if it beeps twice its unlocking properly.
If you get no beeps then there is a fault with door locks/ ccm/wiring.
1 - 8 of 8 Posts
