Hi there, Ive had my golf for a few years now, its done 82k and is a 1.4 s. I will go through eah problem seperately
1. From cold start i get a tapping sound so i had the tappets changed, it got far worse and louder, the mechanic says that it is due to low oild pressure as the tappets cant fill with oil and is a commen problem. Once my engine has been running for a while its fine. im not so sure oil pressure is the problem? Any other suggestions or how pricy is this to fix if it is the oil pressure
2. Im alwyas losing oil!!!!! it tends to be a high revs but in a month of driving i have more or lesss no oil!!!! the mechanic again says low oil pressure but this i believe is to worn piston rings surely!!! also i must admid i did not cheak my oil for a while and had been runninjg on min for a while which would of surely added wear to the piston rings and will casue this oil loss out the exhaust. My tailgate is allways black from the oil
3. constant stalling especially when say doing a 3 point turn!! no idea y, been annoying me for ages, had a new cam belt so the idle belt is running fine. HELP????
I have hered many bad things about my engine that there are many commen problems, any one else feel free to add comments about this engine!!!!
Christian
Christian
